English Axle Disk Brakes
AntonUK - 19/2/16 at 08:17 AM
Hi All,
Quick question, My car has has the sierra rear brake conversion made to an ford English axle.
What disks would it use, standard sierra items or something else?
mcerd1 - 19/2/16 at 08:30 AM
I've seen a few different versions of these kits - what size are the discs ?
ian locostzx9rc2 - 19/2/16 at 08:39 AM
When I converted my axle on a car I had I used fiesta discs , it was a long time ago so I'm don't sure of the part no I'm afraid .
AntonUK - 19/2/16 at 08:43 AM
Outside diameter is 246mm
mcerd1 - 19/2/16 at 09:20 AM
^^^ well its not a sierra disc then - they are 253mm (or 273mm on a cossie)
chances are its a fiesta one, but I don't know there sizes of the top of my head
britishtrident - 19/2/16 at 12:02 PM
Contrary to above I suspect you will find they are the front Sierra from the 1.3 (yes there was such a wimp of a thing!) and early fleet spec 1.6 , I think are the same as Mk3 Escort 100 & 1300
Neville Jones - 19/2/16 at 12:17 PM
We use Mk3 Escort solids for the Sierra and VAG rear disc conversions.
Not sure but something tells me that the discs are 240 od.
Escort Mk3/4/5 all have a 240x10 solid in the base models. Be careful though, as the later cars have a different, less, set back distance of the disc centreline from the hub mount.
Nev.
[Edited on 19/2/16 by Neville Jones]
obfripper - 19/2/16 at 01:35 PM
246mm is possibly a peugeot 307/405/partner rear disc istr they clear the hub flange without machining.
Dave
arrow-engineering - 19/2/16 at 08:16 PM
what he said.
AntonUK - 19/2/16 at 09:59 PM
So on a bit of a whim (and before reading your replies) I passed a motorfactors this morning who had a pair of sierra discs in stock and quite predictably the don't fit...
While I could have easily knocked 6mm off the OD the inner section is the wrong size. I shall investigate your suggestions thanks all.
ian locostzx9rc2 - 19/2/16 at 10:12 PM
Most motor factors have catalogues with the dimensions in
mcerd1 - 20/2/16 at 12:36 AM
so do the online catalogues from the disc makers (most don't let you search by size thought)
also any of these catalogues don't cover every version / model that was ever made, just the ones that they make discs for now...
try this one:
http://www.brakebook.com/bb/mintex/en_GB/applicationSearch.xhtml?reset=1
[Edited on 20/2/2016 by mcerd1]
AlexXtreme - 20/2/16 at 07:15 PM
AntonUK,
With the same car and the same set up I have just measure the disc dia as 240 to 245mm and a thickness of 10mm
I have a partially seized offside caliper that I need to replace so would also like to know what the set up is!
AntonUK - 20/2/16 at 07:48 PM
I found them... turns out they were Mk3 fiesta front discs
Thanks all
AlexXtreme - 20/2/16 at 10:58 PM
any idea of the rear calipers to go with the discs.....
Just looked at your pics of the of your re-build - great work!
What are the front brakes on your car .... mine are old 4-pot ap brakes and just spent the last few weeks re-refurbishing them
AntonUK - 20/2/16 at 11:30 PM
Thanks it's been a long time coming.
All 4 calipers are from a Sierra.
AlexXtreme - 21/2/16 at 09:24 AM
Thanks... just need to work out which ones are on the rear now!
Alex
AntonUK - 22/2/16 at 09:20 AM
Post a picture, people hear a really knowledgeable and helpful.
