Evening all,
Just getting some spare together for a track day and one thing on my list is clutch cable..
Anybody see any reason why I can't use https://www.ebay.co.uk/itm/310612065270 for my R1 clutch control cable???
Phil
Anybody....?
Only thing I could say is that it doesn't have any kind of protective cover, it seems to be bare cable. Are you intending to reuse the existing cable sheath?
AsLong as your outer cable and cable ends will accept 2mm cable it will be fine
Yes using the existing outer cable, will just give it a try I guess!
