Handbrake calipers
nilocp - 17/2/17 at 05:54 PM
Has anyone come across a mechanical handbrake only caliper?
A mate of mine has just been through the test with a Jag based kit car running a separate hydraulic handbrake system. Failed!
Any ideas guys?
Colin
Yorkie - 17/2/17 at 06:29 PM
RD advertise a Wilwood MC4 mechanical park brake caliper in the catalogue.
Not sure how effective it would be though.
[Edited on 17/2/17 by Yorkie]
obfripper - 17/2/17 at 07:00 PM
If your mate is feeling flush, new aston v8 vantage h/b calipers are about £210 each, and pads are £25 a set.
I've got one to mot tomorrow, i'll post up the h/b efforts for comparison.
http://www.astonmartinparts.net/Details/Item/1445/V8-Vantage-Handbrake-Caliper-RH
Aston Martin V8 Vantage 4.3 Genuine TRW Rear Handbrake Pad Set
Dave
B33fy - 17/2/17 at 11:16 PM
I'm fitting MC4 calipers, they seem a nice piece of kit, with sliding mounts etc as part of the unit. £80 plus vat each. They are more effective than the wilwood spot handbrake calipers which by rally designs own admission aren't that effective.
obfripper - 18/2/17 at 05:05 PM
The aston ones were 188 and 203 kgf - enough to pull the vehicle out the rollers with 23% efficiency and more effort available at the lever.
The only difference visible mechanism wise that i could see is the handbrake lever is about 1/3 longer than most cars.
That mc4 look more suitable than the older spot caliper, the old spot caliper struggles to pass mot on a quad based pickup let alone a jag based kit.
Dave
nilocp - 20/2/17 at 05:35 PM
Dont think he can run to Aston calipers!
By the way the rear brake discs are 25mm thick! So that creates a problem!
itsawindupuk - 2/5/17 at 09:09 PM
I'm interested in the MC4 calipers but looks like they are designed for vented discs. Is it possible to use spacers to make it work with thinner discs?
bg0013 - 3/5/17 at 02:50 AM
[img][/img]
[img][/img]
http://www.hispeccalipers.co.uk/svault2si.html
hi spec do these rear caliper's, which are a combo hydraulic and separate mechanical hand brake mechanism, and also a mechanical only style.
they are IVA compliant and can be specced in different widths.
does that help?
AntonUK - 4/5/17 at 06:52 PM
I saw these at stoneleigh £100 a pair kinda wished I'd picked them up now
https://www.rallydesign.co.uk/product_info.php?products_id=10563
