Did the sierra uprights ever come with an abs ring option?
Got a feeling it was only on the 4x4
Yes later cars 1990 onwards on higher spec cars or option on lower spec cars
Thanks l, I shall have to look out for some.. having thoughts of traction control
^^ as above the late model 2wd versions could have ABS
I might have a few pics of the internals somewhere....
[edit]
The ABS ring is actually on the edge of the washer - the sensor is relatively big compared to modern ones (~10mm dia from memory)
The washer and stub axles have splines to lock them together (same hub/spline as non-ABS ones, but different washer and upright)
Sierra ABS upright
ABS upright
^^ in those pics you'll see the alloy blanking plugs I made to replace the sensors
those hubs came from a 1990 2.0 DOHC ghia estate - but any late model hi-spec 2wd car should do (except the cossie)
The rest of the upright is identical to the normal one and uses the same bearings - so would be a strait swap for a non-ABS one
as an alternative Mk3 Granada (and Scorpio I think) hubs all have ABS, but these have a slightly different geometry so would involve lots of other
work to use them properly
[Edited on 17/8/2017 by mcerd1]
