Trying to fit Hand brake and cable saw a picture on here recently but cant seem to find it,any help appreciated.
What brakes and handbrake setup are you using?
Others may have used the same parts and be able to advise on how they did it.
Sorry about that. I am using Sierra Handbrake and cable, just trying to figure out how to attach the cable to the Handbrake and still have have some adjustment
Does this pic help?
Cable was cut and rejoined using 2 x U clamps. Also can adjust length with plastic nut on the outer sheath which is butted up against the rear
bulkhead. I will search for a pic of that too.
[img]
handbrake details 123
[/img]
ETA found the pic of the plastic nut adjuster...
[img]
handbrake adjustment 321
[/img]
[Edited on 11-4-18 by Slater]
[img]
hb adj 1234
[/img]
Same setup on my MK Indy. I did shorten the cable and clamp it back together with a drilled bolt (passed SVA fine like this as well):
[Edited on 11/4/18 by nick205]
I have overall adjustment in the middle with left right balance on the two outer adjusters
[img]
Fully adjustable handbrake
[/img]
Thanks for all the help hope to attack it tomorrow.
Nyloc nuts require a couple of threads showing, Not that it would matter as once the nut undoes a little the pressure on the cable is released.
A better method would be threadlock (Although I am sure considering the tidyness of your build that you did so)
