Wide Track Steering Rack
mattpilmoor - 18/1/05 at 09:35 AM
Hi
What's the best steering rack to use? I'm using a wide track cortina rear axle.
I'd quite like to widen the track at the front but am unsure about a steering rack to match up to the cortina uprights.
Any help appreciated.
Matt
James - 18/1/05 at 10:28 AM
I'd stick with the standard length front wishbones. You know they work (geometry wise) and Jon Ison and Jasper have proved that that they work with a Cortina back axle.
HTH,
James
britishtrident - 18/1/05 at 10:32 AM
Book Escort rack is a too wide between the inner joints ----- if you go wide track all you need is track rod extenders.
mattpilmoor - 18/1/05 at 10:53 AM
I'll go with (castor corrected) book wishbones then.
Matt
