Can anyone help?
I'm looking for enough cold drawn seamless tubing for the bush housings on wishbones and rear links, about a metre all told, either big enough to
take Mark Norden or GTS poly bushes or small enought to take standard Triumph ones.
It seems v. hard to come by and I don,t want to buy a 6+ metre length.
Am currently building an e-bay special!
Welder, donor Escort, Cortina uprights etc. all got locally
off the net.
I'm in Worcestershire if anybody local wants to get in touch.
hi clbarklay,
i asked the same question 2 days ago. i was having trouble finding some too but seems most people use erw not seamless. look on the chassis forum
section and u'll see my original post with all the answers.
Get the tube from the people you get the bushes from- you can't fail to get the right fit that way!
HTH,
James
Dread to think what the cost per meter is though
I decided on which bushes I wanted, got an example to pysically check the size and took it to my local steel stockholder where I got an offcut of
seamed tube the correct size for a fiver.
Mick
Don't see why it'd be that much if it's just an off-cut from the stock they make the wishbones from anyway.
I bought bushes, crush tubes, outer tubing and even the bolts all from MK a couple of years ago for what seemed a very reasonable price at the
time.
James
Oops!
Sorry James I thought you were refering to buying individual bush tubes.
Must get my eyes tested.
Mick
I get all my short lengths of CDS from a local metal supermarket
www.metalsupermarkets.co.uk
they have branches across the country
Andy...
Thanks for the advice, found a local metal supermarket, they seem to be very helpfull, one of the staffs even building a locost.
Got a reply from MNR, they quoted £2.20 per cds tube, which dobles the cost of the bush. Not the same as yours James but all the same, it aint
cheap.
Heafty welded tube (2.5+mm wall) sound the best bet for a road car.
I used thickwall seamed tube and used the lathe to clean up the bore and provide a tapered lead-in for pressing the Triumph bushes home.
Thanks one and all for you suggestions and advice. I'm getting tubing from the metal supermarket and have just got to decide who's bushes to go for
