Evening all.
I was wondering if anyone knew what lenght and spec the pinch bolt used on the sierra fron uprights is? I think it is an M12 item, but I dont have
anything to check! I would get a ford replacement part, but It must be an off the shelf bolt that I can "acquire" from work tomorrow!
Correct
mine are 70 mm, as it also holds my mk cycle wing bracket
koen
Sierra front upright pinch bolts are M12-60m
Brilliant cheers folks!
Out of interest, does this bolt have any particulare means of locking the bolt in place? I'm thinking some kind of threadlock compound, or
possibly a nyloc nut on the protruding thread.
ANdy
Mine is M12 8.8. Long enough to hold cycle wing bracket as well. I drilled clearance hole through upright (result of snapped bolts) and nyloc nut.
That sounds like a good idea.... I had a nightmare getting the pinch bolt out when dismantling the donor parts. I ended up having to weld a new head
to the sheared off bolt, before I could remove it.
Now, Where did I put my 12mm drill!!!
Cheers folks!
