Is there anyone out there that knows if the P100 (cortina shape) front hubs fit onto the cortina mk4/5 front hubs?( i am after 5 studs)
acording to the qh list they have different wheel bearings so asume they are different,try using granada mk1 or 2 uprights with 5 stud fixings
But alas i have already made my wishbones and aquired cortina uprights but if the only difference is the bearing size then something can be modded to suit..cheers for the info
Pilgrim cars made a cheap cobra kit with early granada rear and cortina fronts,they exchanged the front hubs for a 5 stud version.Maybe worth giving
them a call to see how,just tell them youve bought a half built pilgrim sumo and need the hubs exchanged
[Edited on 15/12/02 by bob]
PILGRIM SUMO .............now that is one naff cobra replica, but thanks for the info bob, it could be worth a try.
AFAIK the Granada MK2 uprights were the same as the Cortina but discs were vented and were five stud instead of four.
Could be wrong though....
i can verify you are correct stu.
same for mk1 as well.
atb
steve
Thanks chaps, looks like i might just be able to get them 182 rims on after all.
182? poxy keys, i ment 18"
18's on a seven? Are you a rapper or something?
Kingr
i have been told that it might be a tad over tired so i might stick with the sixteens
