Just found this
http://www.73-87.com/garage/lbs.htm
and was thinking of useing it with a fiesta screw in type pressure reducing v/v.
They sell it in demon tweeks but the ports are 1/8 npt???? Where can you get them fittings from and will it work with 3/16 pipe?
Any ideas peeps?
Graham
interesting bit of kit.is it road legal?
will it affect the sva? wouldn't mind trying on out, got to be silly money thouigh
afaik all american stuf is imperial,why not use the fiat uno valve only £20
do the peugoet not have a valve that works like that lbs thingy???
near sure theres one on the 309s and 205s
Syd B, Conrod and myself were chatting about Uno/Mini bias valves on another thread on this forum a few days ago. I put a drawing of the Mini bias
valve conversion in my photo album here. I have further written instructions if anyone requires them.
It's simplicity itself.
One more sleep!
will it affect the sva? wouldn't mind trying on out, got to be silly money thouigh![]()
FIAT bias valve
That looks quite neat. From which uno??
Graham
Graham all the uno valves are the same i have 1 spare left £20 to you inc p+p
I have been looking for a mini valve for ages, all my local scrapies don't even have any minis !!!, the mini valve apparently costs £109 new ...
yikes
So, presumably the uno valve setup like Bobs works the same way as the mini version ?
where abouts on an Uno is the said valve located ?
thanks
Reduction valve is at the back on FIATs near axle me thinks.
Look in for sale section for a good deal on these from conrodkid,about a third of the price FIAT dealers want.
[Edited on 2/1/03 by bob]
bob, you OK ? only you replied but stopped short of saying anything. Hope you didn't collapse and hit the keyboard just as you were about to deliver information to the masses !!!
weird a minute ago your post was blank, then after I posted your text appeared !!
ahhhh found the edit button !!
[Edited on 2/1/03 by givemethebighammer]
FIAT valves available from theconrodkid at third the price of mini ones
[Edited on 3/1/03 by bob]
i must have missed something in the translation...i thought the original post was about a gadget that reduces the risk of rear wheel lock up by
delaying initial pressure...This uno/ mini idea (although a bloody good adaptation) is all about brake bias, something a whole lot different?
Isn't the original gadget used by yankee stock cars because they are not allowed bias valves?
Just a thought, i guess someone will put me right..
Yep your right , Hence " a fiesta v/v and a lbs" but I now think the fiesta v/v is a type of lbs..... Still looking into that.
Just seen a Fiesta at my mates garage. They have rear brake bias things screwed directly onto the master cylinder. Small, light and neat. Although
they are not adjustable, just thought I'd let you know.
Graham
