I'm using a Sierra master cylinder. I was gonna block off one of the two front pipe connections, and then split the single pipe half way around the
front system (I've already begun to do all this)
But after seeing Bob's set-up of seperate pipes to each of the front calipers I'm now wondering which way is better - or does it - as I suspect - make
no difference at all.
best way would be to have seperate pipes to the front calipers and a single to the rear T peice,remember front outlets are nearest the pedal
I think it depends on the master cylinder - on mine, I have 2 outlets on the front (i.e. furthest from the pedal) that go to the front brakes. The single outlet nearest the pedal goes to the back brakes.
Thanks Dave,spot on.
just checked my notes from dismantling the sierra to confirm phew,was woried there for a bit.
Cheers chaps......
there are lots of diferent cylinders 3 or 4 port some split diagonaly but most are the way i described,works well on mine
I can confirm they work well on johns car,as long as they work i suppose.
Have read somewhere of people swapping them around to change pressure.
[Edited on 29/12/02 by bob]
The only word of wisdom about ford Master Cylinders that I have to give is, DON'T EVER remove the plastic tag around the cylinder, cos there are so
many variations that ford did, that the Numbers on them are critical for getting the right replacement, should you ever need to replace.
And the Numbers are NOT stamped on the Bodies
The front brake line ports are usually-but not always the furthest AWAY from the pedal. Idea being that the rear brakes get activated very slightly before the fronts when brake is applied (motorcyclists will know about this theory...)
Originally posted by Stu16v
Idea being that the rear brakes get activated very slightly before the fronts when brake is applied...
Ok so I am confused now, the Sierra (RWD) amongst others have a front/rear split and a 50/50 M/cylinder. And admittedly, I havent had many master cylinders apart (because I always replace them rather than f*ck about trying to re-seal them) but I dont ever recall seeing one with different sized pistons in......
Hi Stu,
NO! The Sierra mcyl (p/n 74066315 - I think!) is definitely NOT 50/50. It is nearer to 62/38, but 60/40 will suffice.
Just to clarify things :-
1: Assume that the mcyl is mounted with its flange towards the pedal, & its closed end towards the front of the vehicle (ie in same direction as per
donor).
2: The piston nearest the pedal is the primary, & that nearer to the front of the vehicle is the secondary.
3: The primary piston will always travel more than the secondary, by compressing the primary chamber. Theoretically, this is a simultaneous cut-off
mcyl (ie both chambers together).
4: In order to prevent piston seal damage (nibbling) by the cut-off port, the rear brakes are always connected to the primary chamber. This ensures
that when the shoe return springs cause the primary chamber to rise, the primary piston seal has stroked safely away from the cut-off port.
It might be useful if I scanned in some diags to help illustrate the above points, but if you still want more clarification, let me know.
Minor differences are in, bore size, piston and seal constuction, stroke length and front to rear effort compensation by virtue of the floating piston
and valve assembly therein.
Some modern designs of master cylinder are sooooo sensitive that ('90' on vauxalls come to mind) that if you push ANY fluid the wrong way (push a
piston back to change a brake pad) you end up with a reversed seal in the Master cylinder and end up buying a new one.
Enjoy. Wish you all a Happy New year.
Dick, thanks for your reply. I would appreciate any pics or info you could scan for me because I am having difficulty getting my bonce around the
theory.....If there is no air in the M/cyl, the pistons must travel as one as fluid cannot be compressed right? And if the bore size of the cyl is
same end to end the same amount of of fluid must be displaced for a given pedal stroke. It does look like I need educating....
Cheers, Stu
I thought I would add my comments for what they are worth.
Surely the fluid in the hydraulic system is constantly travelling in both directions when the brakes are applied and then pressure is removed from the
pedal
When the pedal is pressed, fluid is displaced from the master cylinder, down through the brake pipes and hoses and into the brake cylinders and
calipers, thus allowing the brakes to be applied
When pressure is removed from the pedal, the return springs on brake shoes and the fluid seals in the calipers cause the pistons to retract, pushing
the fluid back in the opposite direction, up through the pipes towards the master cylinder
(I know it doesn't travel all the way, but hopefully you understand what I mean)
On another note, the only car I have seen with a different size primary and secondary piston is a mini. When a replacement master cylinder was
supplied it came with new brake pipes that had to be fitted otherwise the rear wheels would lock up when you applied the brakes
That's what I love about the forum - you ask a simple unassuming question, and a get a wealth of fascinating info in return!!!
BTW - Yes it is 8.15pm on new years eve, that's what having a family does for you!!
I would appreciate any pics or info you could scan for me because I am having difficulty getting my bonce around the theory.....
I have dug a few manuals, techy books etc out and at the moment at least, they all seem to back up my original understanding of how a dual circuit
M/cyl works. Interestingly, an old manual for the Mk2 Escort shows the the front/rear pipes on one way for LHD, and the other way for RHD!
Assuming the primary and secondary pistons/ports are the same bore size (which the majority of cars are AFAIK) the hydraulic pressure supplied by the
cylinder is the same. The primary piston cannot actually compress any more if there is no air in the system, what does happen is that fluid is
squeezed into the primary circuit. But the point is reached when the primary piston drives the secondary piston foward (via the fluid in the primary
chamber) and subsequently begins to activate the front circuit. There maybe slightly more fluid available to the rear circuit by virtue of the fact
that the primary chamber collapses in size, BUT actual pressure in the pipes will be equal. There is a front to rear brake bias, but this is usually
sorted by the different hydraulic and mechanical design of the front and rear brake components, not forgetting LSVs and inertia valves which will
alter the static theoretical ratio again. Otherwise most other cars are to be found with pressure limiting valves in the rear circuit.
But please, if you can supply info to educate me otherwise, please do, because after all, every day is a school day....
[Edited on 3/1/03 by Stu16v]
I also wondered how the front and rear pistons could displace different amounts of fluid, but after thinking for a while and loking at a diagram i
realised that altough the bore of the cylinder is the same the piston area is not.This is due to the fact that the piston nearest the pedal is joined
to the second piston by a pushrod that takes up some cylinder volume , the effective area is therefore less than the front piston that is full bore
size and therfore a larger area.
Paul
I have dug a few manuals, techy books etc out and at the moment at least, they all seem to back up my original understanding of how a dual circuit M/cyl works. Interestingly, an old manual for the Mk2 Escort shows the the front/rear pipes on one way for LHD, and the other way for RHD!
Assuming the primary and secondary pistons/ports are the same bore size (which the majority of cars are AFAIK) the hydraulic pressure supplied by the cylinder is the same. The primary piston cannot actually compress any more if there is no air in the system, what does happen is that fluid is squeezed into the primary circuit. But the point is reached when the primary piston drives the secondary piston foward (via the fluid in the primary chamber) and subsequently begins to activate the front circuit. There maybe slightly more fluid available to the rear circuit by virtue of the fact that the primary chamber collapses in size, BUT actual pressure in the pipes will be equal. There is a front to rear brake bias, but this is usually sorted by the different hydraulic and mechanical design of the front and rear brake components, not forgetting LSVs and inertia valves which will alter the static theoretical ratio again. Otherwise most other cars are to be found with pressure limiting valves in the rear circuit.
I also wondered how the front and rear pistons could displace different amounts of fluid, but after thinking for a while and loking at a diagram i realised that altough the bore of the cylinder is the same the piston area is not.This is due to the fact that the piston nearest the pedal is joined to the second piston by a pushrod that takes up some cylinder volume , the effective area is therefore less than the front piston that is full bore size and therfore a larger area.
Yes this is true but the length of travel of the primary piston is limited by the stroke of the secondary piston , therefore limiting the pressure
developed in the primary circuit.If the secondary circuit was disconnected then your thery would apply but the secondary travel limits the pressure in
Paul.
Hmmmm. In all the exploded piccys I have sourced so far, the piston areas for both chambers have been pretty much identical. If your theory was the
case, then that would mean the primary port would have the mechanical advantage i.e imagine using two different sized M/cyls as in a bias bar system,
the smaller one will allow greater force to be applied to an axle, but for greater pedal travel.
Originally posted by Dick Axtell
Can get to a scanner when the office opens next week; am delving thru my files to find the appropriate pics.
Yes this is true but the length of travel of the primary piston is limited by the stroke of the secondary piston , therefore limiting the pressure developed in the primary circuit.If the secondary circuit was disconnected then your thery would apply but the secondary travel limits the pressure in the primary circuit.
Wisdom is not given it is earned. Give people enough direction & they usually reach the right conclusions.
That what I like about this forum. People learn lots.
Enjoy.
Originally posted by paulf
loking at a diagram i realised that altough the bore of the cylinder is the same the piston area is not.This is due to the fact that the piston nearest the pedal is joined to the second piston by a pushrod.quote:
Definitely NOT. That "pushrod" is either a stroke limiter, or a means of carrying the primary return spring. It merely abuts the rear face of the secondary piston, and is not sealed to it. Therefore, the primary piston area ia the full diametra area.
Still working on these diagrams - always necessary for such explanations.
Dick Axtell - 10/1/03 at 10:19 AMquote:
Originally posted by jollygreengiant
The only word of wisdom about ford Master Cylinders that I have to give is, DON'T EVER remove the plastic tag around the cylinder, cos there are so many variations that ford did, that the Numbers on them are critical for getting the right replacement, should you ever need to replace.
Hi JGG, Couldn't agree more. Any ID is better than none. However, any number stamped on a mcyl body will probably be a casting part number, and will be relative to the mcyl supplier, not FoMoCo.
