I have my SVA tuesday on my velocity. I know it's close but i have been un able to set the brake bias up until now due to other issues.
The problem is
A) The rear wheels are stiff to turn by hand when the car is off the ground weather the brake pedal is depressed or not. I.e there seems to be no
difference with brakes on or off. If I put the handbrake on they lock up completely.
B) no matter which way i adjust the bias bar the front brakes lock up at the same point on the pedal travel.
Background.
When bleeding the brakes at the front. They move easily when the nipple is open and i get lots of fluid. When bleeding the rears the pedal is still
stiff and i don't get anywhere near as much fluid from them.
Question.
Is this normal for the rears not to lock up on the foot pedal?
Which way should i adjust the bias bar i.e. left or right?
Thanks for your time. Phill
if the rear wheels are stiff to turn by hand with no pressure on the brake edal and the handbrake released it sounds like they are binding (pads/shoes
not being released propoerly).
Did you rebuild the rear brakes and are they set-up/adjusted properly?
Nick
Have you located the pads properly on the disc's? The tang on the rear of the pad needs to fit into the slot on the caliper piston. If the calipers haven't been re-conditioned - take the car for a short run and bed them in... take it stready you don't want to overheat the disc's though...
Have you got a LSD? they are very stiff to turn as you describe.
If you have one, don't worry about it.
If it is a brake related problem then I haven't had a dual M/C system with a balance bar and I confess I am not sure how to bleed those.
Good luck
Mark
Is your handbrake cable slightly too tight?
How many clicks do you get when you pull the handbrake, if it's 3 or less, my guess is that the hanbrake cable is too tight.
Pat...
It could also be debris in your brake lines clogging and maintaing pressure on the rear calipers. If you can't flush fluid through the rear brakes lines then that is your culprit.
Right,
spent a whole day on the damn things and have got no where, unless you count the handbrake being worse as progress.
Thanks to everyone who has replied.
Here's my replys to your comments
Binding, I have had the calipers off and made sure there is no paint etc so the pads can move freely.
As said by mookloid I belive the wheels are stiff because of the LSD i have. As the pads are not even touching the disc when the brake pedal is used
or even when it is not. I.e. they aren't binding as they aren't even getting there in the first place.
The pads are located correctly, the tag Hellfire spoke about is in the slot.
I have a constant flow of brake fluid. I even took the calipers off and hung them up so they were the highest point so no air could be left in the
hoses as the bleed nipples are at the bottom of the caliper when in position.
I took it for a run round the local car park and did 4 miles to try and bed the brakes but the small amount of surface rust that is on the rear discc
wasn't even removed. Proving the brakes aren't even touching the disc.
So the only thing i can think of now is adjustment as the piston can be moved in and out.
Therefore has anyone got any idea how they should be adjusted/setup? |I can't find anything in the haynes manual on the adjustment.
Or any more ideas as to why i have no back brakes?
Try pulling the handbrake on and off a lot. I believe this adjusts the mechanism inside the calipers - it worked for me
mark
And try tightening the handbrake cable if they're definately not binding.
Pat...
Hi Phill
Are the calipers new? if not did you wind in the pistons when you fitted the new pads? I've heard you can break the adjuster if you push them
in
Adrian
After 3 days of messing and getting nowhwere the sva came round and the tester found there were no brakes at the rear.
However the guy was very helpful and knowledgeable he gave us a couple of tips and suggestions as to what may be causing the problem. The re test is
booked so i will be fixing the brakes (fingers crossed this week) Will let you know what solves the problem.
Thanks guys for all your help
