Hi I put the nut for the steering wheel ever so safe that i cant find it??? wot size nut is it Lenny
not sure of the size but if it's a standard sierra one then I have one you can have, I can send it asap if you want.
Rich.
M14 coarse rings a bell...
What steering column are you using Lenny?
[Edited on 17/9/05 by Stu16v]
Standard Sierra column used a nut, adjustable uses a bolt.
