As requested, here's my take on the Locost De Dion axle (thanks go to flak monkey for hosting it).
No warranty is given or implied as to the design's suitability for any purpose. It is as yet unproven in a Locost, but is freely offered for
educational and comparative purposes.
If you decide to have a go at constructing this interpretation and injure yourself or cause some damage, then you're an idiot and there's
nobody to blame but yourself.
ADDENDUM In drawing # 08 the material spec states 4140 or EN24T steel. It should read 4340 or EN24T steel.
RortyDeDionAxleAssembly
[Edited on 28/10/05 by Rorty]
does this fit straight into the book chassis?
Excellent! Cheers bud, just what I was after!
a good looking set of drawings, but i do wonder why you bothered rorty? these plans (in essence) have been around yonks, are on the locost cd and the
locost7.info site iirc
Ned.
Well Ned, I haven't seen either of those sources so I'm very grateful for Rorty's efforts!
Rorty - I have a question - on your drawing you call one part the 'Watts Linkage', but it looks like a panhard rod to me. Or is that my
ignorance showing?
ok well i can't find the stuff on the locost7.info site, but i'm sure i've seen it online somewhere.
i have the locost cd so can post the pics if it'd help anyone.
Ned.
Ned seeing as you have access to three sets of plans now, what are the differences between the plans? Are they all pretty much identical? do they all
use the same thickness steel?
Is there scope for a best of breed here?
(Rorty, i'd also like to add my thanks, this is the first time i've seen proper plans. I keep thinking about de-dion and you might have
pushed me over the edge!)
happy to admit my mistakes.
rorty's is more similar to the gts dedion as its 2 straigh pieces joined in the middle, the locost cd version is a bent tube.
pics now uploaded to my photo archive from the locost cdrom :
http://www.locostbuilders.co.uk/photos.php?action=gal&user=ned&folder=dedion
but they have been posted before as they're in someone else's archive already as the system renamed some with a '2' at the front
to signify that name already exists in the uploads folder on the server.
I'm sure Rorty's input is and will be appreciated and is a better engineering drawing than the sketches with dimensions linked above.
Ned.
Certain parts look like the one i did for the GTS....but then nowt is really new on cars anyway just done differently
Good set of plans though Rorty, i like your English Wheel stuff on your webby too....pat on the back there
My Acrobat wont open it , says it cannot decrypt, any ideas?
[Edited on 21/10/05 by Surrey Dave]
It opens OK with Adobe Acrobat 7.0.5 for me.
Maybe you need an upgrade?
Cheers Rorty.
I was going to make myself some caliper brackets.
Your drawing will save me a lot of measuring and designing.
Just as a point, there are a few dimensions missing off the drawings, although with a little common sense it's not difficult to work them out or
best guess them.
Originally posted by zzrpowerd-locost
does this fit straight into the book chassis?![]()
Originally posted by ned
a good looking set of drawings, but i do wonder why you bothered rorty? these plans (in essence) have been around yonks, are on the locost cd and the locost7.info site iirc
Ned.
Originally posted by David Jenkins
Rorty - I have a question - on your drawing you call one part the 'Watts Linkage', but it looks like a panhard rod to me. Or is that my ignorance showing?![]()
Originally posted by BKLOCO
Just as a point, there are a few dimensions missing off the drawings, although with a little common sense it's not difficult to work them out or best guess them.
"Due to their propensity to sue anything with a pulse, Americans are explicitly requested not to attempt to construct this assembly either in
part or in whole."
Does the "hub bucket" not need cut outs for the bearing carrier bolts? It looks a bit tight in the drawing, and I think the GTS axle required cut outs.
Ned.
ok, i've no engineering background so please ignore the ignorance.........
what made you pick the steel thicknesses you've done? Just thinking that some of them seem majorly heavy duty compared to what we're using
on the locost chassis.
Yes, it's designed around The Book's chassis dimensions.
So if i built the book chassis this would fit straight in? The Gts de dion drawings show the bottom chassis rails flat instead of angled
Hats off to Rorty.
Seems to me that all these threads start with questions, and its damn nice to see someone start a thread with a solution.
solution, solution ......... its just just made me question my whole axle decision 5 years into my build. I don't call that a solution, i call it
bloody annoying & another 2 year delay.
Whats that quote again, its not the destination, its how you get there!
what made you pick the steel thicknesses you've done? Just thinking that some of them seem majorly heavy duty compared to what we're using on the locost chassis.
Bob (Rorty), you're a good guy. Everybody is usually just sucking the information out of this place. You are one of few that is constantly
refreshing it with consistent quality info.
Thanks.
At first when I read this part of your pdf I was a bit miffed...
"Due to their propensity to sue anything with a pulse, Americans are explicitly requested not to attempt to construct this assembly either in part or in whole."
Originally posted by sgraber
Bob (Rorty), you're a good guy. Everybody is usually just sucking the information out of this place. You are one of few that is constantly refreshing it with consistent quality info.Thanks.
You mean in 'other' countries people take responsibility for their own actions?![]()
Will you make an exception for me? I promise not to sue since I am apparently one of the few Americans that am willing to take responsibility for my own actions...
I'm sure you've come across the sort of people that rider's aimed at though. I amended the PDF file so the Panhard bits are now correctly refered to as Panhard bits (funnily enough) and not Watts bits as originally.
I don't know what my brain was doing at the time!
I've also specced the size of the hub retaining bolts.
Very Impressive -- neat -- cool -- hot -- sweet --- and and other adjective that means you diid a good job.
Rorty, I bought a GTS de-dion axle because one of my worries was getting the bearing carrier mounting plates perfectly parallel and exactly in-line. For those contemplating building this, do you have any cunning tips, or is it a case of measure twice, cut once, throw it away and have another go?
Rorty, Thats a really neat bit of design work & will save me a heap of work on my effort. Many thanks for your efforts.
A couple of queries if I may?
I'm assuming that the trailing arm mounts are designed for book length arms which from memory are about 304mm ( 12" ) ?
Yor panhard mount on the tube, which you describe as being made from 4140(?), is this one piece?, & is the seperate piece shown, like a washer
with one conical side, is that the safety washer? Thats what I've taken it as, sorry if this sounds thick.
Thanks, Cheers Steve.
How many people on here know what 4130 and 4140 are? How difficult is it to get?
And do they know it has to be welded very carefully with special filler material? I had to search the inet to find out.
Ordinary mild steel is what the book specifies, is this good enough?
I've got plenty of stainless to hand, use it in the salt, can I use that?
Sorry for the Q's
Nev.
Why would you want to use 4130 or 4140.
You DEFINITELY don't want 4140, it is a tool steel!
4130 would be nice but as you say needs careful welding and to make any advantage out of it you will need very thin section tubing, which will be a)
very tricky to get hold of and b) very expensive.
cheers
NS (engineer in an alloy steel tubemaking plant!!)
I am a bit confused by this now. Rorty said a few posts back that he preferred 4130 and somewhere mentioned 4140.
So what do I use? We have plenty of 316 and 306 stainless in the shed, is this ok?
Nev.
Yor panhard mount on the tube, which you describe as being made from 4140(?), is this one piece?, & is the seperate piece shown, like a washer with one conical side, is that the safety washer? Thats what I've taken it as, sorry if this sounds thick.
Sorry for the Q's
Nev.
4130 would be nice but as you say needs careful welding and to make any advantage out of it you will need very thin section tubing, which will be a) very tricky to get hold of and b) very expensive.
cheers
NS (engineer in an alloy steel tubemaking plant!!)![]()
Thanks Rorty, I've got that now, I'm Ok with the rest ( I hope)
, off to look for someone with a lump of 4340
Cheers, Steve.
Sorry if this is a dumb question and sorry to drag up this tread again...
However, just to satisfy my mind, are the drive shafts from the Sierra standard lenght or have they been modified in any way.
A four inch Deon tube in 14 gauge is fairly hefty.
Caterham used a 2.5 inch tube (I don't know the gauge) and the LaBala project uses 3 inch 16 gauge.
I reckon a 2.5 inch tube in 14 gauge would be man enough or 3 inch in 14 gauge to allow some leeway in welding skill.
Surely four inch would hold up a monster truck?!?!?!?
