Dear all,
I am currently going about prepping to fit my Sierra rear axle,and need some shock absorbers that fix to a bracket on the subframe and to the side of
the body using a bracket.I'm very confused however between adjustable shocks and gas dampers.Do the dampers,which have no thread on them,just fix
onto the rear axle without a spring,and the air inside is used to provide the spring effect(compressed air bouncing back),or do you have to buy
springs that fit to the dampers?
Any enlightenment on my ignorance would be greatly appreciated....
http://www.ridetech.com/productinfo/cat04images/shockwave_prodshot.jpg
Thats air ride which uses air to support the vehicle and a damper in the middle.
http://www.indiamart.com/jantashockabsorber/images/pic4.jpg
Thats a damper which is JUST a damper. Requires a spring to support the vehicle.
http://www.modernperformance.com/dcx/2k_kw.jpg
Those are coil overs that are dampers, and springs to support the vehicle.
Hope that helps.
Originally posted by Harry B
.Do the dampers,which have no thread on them,just fix onto the rear axle without a spring,and the air inside is used to provide the spring effect(compressed air bouncing back),or do you have to buy springs that fit to the dampers?
