Apart from Rally Design, who does the cheapest Master Cylinders?
Scrapyards?
ok, i want a decent new one!!! After single output ones to fit on a floor mounted, biased pedal box.
Got mine from MAC#1.
Simon
Just noticed you want single output type, mine was the standard dual output, sorry.
[Edited on 29/3/06 by asn163]
haven't found cheaper than rally design mike
Hi try brake comp i think £19 can't remember if thats plus the vat but certinally plus p&p
cheers matt
that's cheaper than rd!
I've got a spare 3/4 inch Bore Master single circuit. It was to be used for a clutch, but change of plans left it spare as i've use a bike
cylinder instead. It has been fitted to the car to test but never used.
U can have it for £10 + Postage if intersted.
cheers
Ian
and if you don't want it mike I'll have it!
cheers matt
