Because of the exhaust I've got an extra UJ in the steering colum.
But how do I make a support to hold the colum?
Do I have the colum 'rolling' in rubber of can I have an aluminium bracket with a steering colum?
Any ideas? Photos?
Many thanks, Lennart.
i used a rose joint,measure your shaft
and get a joint
with the right sized hole
I used a rose joint, more pictures in my gallery by clicking the www button below. main picture here.
Regards
Rich
BTW it does have locking nuts on now!
Thanks for the solution about the rose joints!
I've got a standard Dax steering colum extention of 15mm (5/8"
On the Burton Power site there are quite some 5/8" rose joints, but which one should I need?
https://www.burtonpower.com/dets_product.aspx?PGrp=21015&PSet=98
Maybe not really clear to all. What I did mean was, what's the difference between underneath rose joints and which one should I use for
supporting the colum?
Burton Power doesn't answer my e-mail.
It is now a generic term for spherical rod ends. You don't need an expensive race item for your column bearing. The cheap 5/8"x5/8" right hand thread would do the job. You can get them a lot cheaper from Nick Skidmore on here if he has any or a local bearing supplier would carry them.
