Good morning, I went to have a look at Silverstone on Saturday I thought it was fantastic, it reminded me of our team racing days in the model cars.
Congratulations to all who took part and of course all the organisers.
One thing I noticed apart from my roll cage being much heavier than most is the suspension setup, my car is like rock solid with hardly no suspension
travel when pushing down by hand, I have to stand on the back and bounce to get any travel, at the front I can't realy get much action at all. I
have noticed in the few times I have driven the car that once the track is damp or wet it's like driving on ice. I think my springs are too hard,
I have gaz shocks and the wishbones are copper greased and do move freely. What spring weights do all you use front and rear does there seem to be a
common setup or does it depend on driving styles etc. I also noticed people changing the damper settings when I change mine I can hardly tell a
difference is this the springs again.
Regards Steve Evans.
What engine do you have? Have you converted to a bike engine? As you will need lower rated springs for the lighter engine.
1300 crossflow racing in locost championship.
Regards Steve
Hi - I have spent a long time investigating spring rates. For what they are worth I have summarised my thoughts in my build diary no 14 at
http://www.Locostsa.co.za/BuildDiaries/Ivan/My_Diary_14.htm
Hope this helps you.
Do you know what your spring rates are? Then maybe you can ask someone what sort of range they are using. If its for racing a fellow competitor might not want to tell you exactly what they are using!
