... I'm gonna be a gynaecologist
In the meantime I've been practicising:
speedo panel
Small panel cut out behind battery to gain access to speedo (cable snapped at speedo head!) - after some fiddling, managed to undo the nuts and the
speedo is out.
Eventualy will have a DC motor to drive the speedo to compensate for speedo drive/speedo mistmatch and be programmable for different wheels sizes.
Must be easier just to fit an electronic speedo , Racetech £60 ish , calibrated by one control on the back..............
Talk to http://www.speedycables.co.uk/ who will make whatever length of cable with whatever end fittings you want for about the same price as a main dealer will supply a standard one.
Hi what sort of crank breather is that?..... looks like a coke tin..............
£81 built mine in 1999/2000 that's inflation
http://www.merlinmotorsport.co.uk/INSTRUMENTS-RACETECH-Electrical-Gauges/c1_354_356/index.html
You can pay £40 + just for a right angle cable drive..............
[Edited on 31/10/06 by Surrey Dave]
