Is it straight forward to connect an a-series engine to an escort diff?
Do I need to make up a hybrid prop?
Dave
Gear box to prop is easy as you've guessed all you need is a suitable prop with the correct ends on it.
Simplest way is use a Mk1 Escort or Mk1/Mk Cortina or Mk1 Capri Axle, which has a flange for circlip type UJs.
Of course because all the gearboxes used on A series engines are seriously awful and weak a good option is to mate the engine to a Ford type 9
[Edited on 7/12/06 by britishtrident]
Interesting ...
Is it a simple job to make the type 9 box
fit?
Dave
Depend upon the engine really.
New engine backplate required the Midget/Sprite guys and Morris Minor duffle coats do it because they are running out of 1300 Marinas to fillet the gearboxes out of.
Dave
Good input.
Dave
I think the earliest seven used a ford side-valve IIRC. They were seriously expensive cars in their day considering you got nearly nothing!
Its easy to make a prop for the A Series to the Escort axle. The A Series gearbox reverse sleeve yoke is 1140 UJ size. You can get a flange to suit
the escort in 1140.
So you can get, such as a Minor prop and then shorten to suit with the correct flange. All parts except the A Series reverse sleeve yoke are available
new from propshaft firms.
Dunninh and Fairbank will be able to sort you out.
John
