Got round to sorting handbrake on my part-built Tiger today. This is how the handbrake cable is at the moment - looks wrong to me, I presume the
sleeve should be fixed in to that hole in the drum, using the nut that's there inside? Thanks...
I don't think so. As far as I remember, the handbrake cable is not fixed inside the brake backplate. I think I unhooked the nipple and the
handbrake cable just pulled straight out. It's held in only by the tension.
I could be wrong though
Isn't the threaded end supposed t to be at the adjuster end, not the back plate
cheers
Chris
It doesn't look like my Sierra cable (I'm on drums).
With drums you have an end with what looks like 4 small tangs at the compass points around the cable. You poke this through the drum back plate and
the tangs stop the selve being pulled back out.
Thats not a Sierra cable. Sierra one has spring clip/tangs on the drum end and a plastic barrel adjuster screws along the outer at the other end then
loops back to the other side via a fixed outer.
Adrian
