13" rims on sierra rear discs
ever88 - 2/7/07 at 06:11 PM
hello all
having difficulty fitting 13" rims to rear sierra disc brakes set up.
I've ground a bit off the caliper but think it may be best to use spacers and extend the wheel studs.
any ideas how others have cleared this problem and are extended wheel studs easy enough to get hold of
grateful of any help
Wadders - 2/7/07 at 06:17 PM
Hi
Rally design sell longer wheel studs and spacers. depends how much clearance you need to gain.
Al.
Originally posted by ever88
hello all
viatron - 2/7/07 at 06:27 PM
Just done this on our Avon, we eventually changed to Hi Spec rear calipers, 10mm spacer, longer studs and still had to grind back the ears on the brake pades!!! Make sure its worth it!!
Also bought some Weller Formula Ford Steel Wheels which helped.
Mac
carlgeldard - 2/7/07 at 06:38 PM
13" Compomotive CXR Wheels job done!!!!!!!!!
Carl
PS Not Locost This route will cost £400 at least.
[Edited on 2/7/07 by carlgeldard]
StevieB - 2/7/07 at 07:58 PM
Carl
But you do save on pricey alloy calipers, about £450 for the back in in itself!
bigrich - 2/7/07 at 09:45 PM
andyps - 3/7/07 at 08:38 PM
Bigrich - is that the hard way because of writing all the numbers on the cheque
