Ok rather a vague crappy question I know but how strong are these chain drive diffs used on some of the BEC cars? (no I'm not going BEC I can assure you) would they for example handle the weight of a saloon car day to day without falling too pieces? Not thinking of masses of power going through it rather just a high torque most of the time.
We know you really want bits of a BEC in your car but why would you want to put an alternative diff into an everyday saloon car??
just pricing stuff out for a project and working out the most suitable parts to use
arent some of the chain drive diffs just modified car diffs?
I would think the weakest link will be the chain myself rather than the diff. I guess a double chain might be an option using two sprockets bolted to the diff / gearbox output???
Originally posted by Miks15
aren’t some of the chain drive diffs just modified car diffs?
Is this for your electric car idea by any chance?
The Sylva R1ot uses a fiesta diff, without the casing. The chain wheel bolts to where the crown wheel used to go.
so range and top speed are irrelevant, I have
the Volvo for long distance anyway. The cars getting fully done up right now so thought this was the ideal time to convert it. I was going to use
water cooling for the motor to heat the demister. The sprint R users the fiesta diff internals
If you want to uprate a chain drive, use a duplex chain.
I had found you a lovely piccy but for some reason I cant upload it.
Look for "duplex chain" in Google images.
Edit to add image
Image deleted by owner
[Edited on 10/4/08 by MikeCapon]
certainly looks the way to go
cheers
I know of a Hyabusa Trike (claimed 178hp) with a single chain driven Reliant Robin axle.
It's been on the road for about four years now with no problems, and the owner rides it like he stole it!
I think the crownwheel and pinion are the weakest link in a normal setup.
Neil
All the chain drive diffs apart from really specialist (& expensive) stuff use car diffs. I would agree that if there was a weak point it would be
the chain, but if you can transmit 'Busa power usedas it is in something like Z cars Mini without a problem I really don't think you're
going to have a problem with an electric motor. The biggets loading on a diff is when you rev up (particularly with a big heavy car flywheel) &
dump the clutch - I can't imagine a similar situation with an electric motor.
You will also be saving most of the weight of a big cast casing - the sideplates on chain diffs don't weigh much.
Russ,
What did you uses on the Furor? you put quite a bit off power through it with the two engines. Do you have a linky?
Like you say the initial starting torque really isn't going to be very high especially without using a gearbox, I think the motors peak torque is
around 4000rpm but I'm not after a speed machine so don't care about 0-60 times.
[Edited on 10/4/08 by Mr Whippy]
Peak torque on a motor (unless there's some kind of controller interfering) is at zero rpm.
My friends most recent hillclimb cars put nearly 400 Bhp and 300nm of torque through a fiesta diff. They havent melted yet, but then again its probably done less than a hundred miles.
On the Furore - the existing car that is - it doesn't have a diff, each engine drives each rear wheel separately so power is split between the 2
drives - around 137BHP & 80 or so Nm torque each.
I'm sure you'd have no problem with any normal chain drive bike diff.
