Any one know any tricks to ensure that a kit car will pass the self centring test,
There were a few posts a couple of weeks ago about this and some suggested using valve srpings under the gators.what stage are you at as it only has to have a tendency to self centre, not fully self centre. I believe what the tester is looking for is that it does not carry on turning in the direction as he goes forward.Have you tried a search yet.
slightly overinflated tyres helps
wayno!!!
As does a bit of toe-out and if using mushroom adaptors, a bit of trailing hub and not too much camber...
I have been a lucky git, mine self centres from when i put it together so its staying exactly as it is until after the test!1
I built my chassis by the book years ago and have just failed SVA on self centre, but more to the point it's nasty to drive, so I spent to-day
grinding off the top wishbone brackets, making new ones and welding them on 25 mm further back. I've now got 6 degrees of caster and nowhere to
put my coilover. So I need to make different top wishbones.
Bugger
FU2 Ron Champion!
My SVA examiner said "you know you should really do something about the KPI because you've got didly squat self-centering".
To which I said "yes, of course, it's on my list of jobs to do"
To which he said "if would be a shame to drag you back here just to see that you've re-welded the wishbones"
Jammy or what!!!
i think hes called steve the guy who does the aries 7 is a bit of a guru on the front end setup i,m sure he would help if you asked him
les g
FFS don't put valve springs in your rack! It's the biggest bodge of all time
Originally posted by BenB
My SVA examiner said "you know you should really do something about the KPI because you've got didly squat self-centering"........
KPI has an effect on self-centering not as large as the effect of caster but useful.
Trouble kpi isn't easy to alter.
Caster is a dynamic effect which relies on roadforce, but KPI and Camber cause the steering to move under the force of gravity.
Often, if you dial in more camber, the car will tend to self center more effectively because the effect is for the tire to "jack" the car a
bit more than just the KPI will do as it turns thru an arc.
Many (American, at least) cars from the fifties and early sixties had factory alignment specs which called out negative caster, relying entirely on
KPI to center the steering.
[Edited on 29/4/08 by MustangSix]
Often, if you dial in more camber, the car will tend to self center more effectively because the effect is for the tire to "jack" the car a bit more than just the KPI will do as it turns thru an arc.
Many (American, at least) cars from the fifties and early sixties had factory alignment specs which called out negative caster, relying entirely on KPI to center the steering.
My view, for what it's worth, on all these 'tricks' to fool the SVA man into thinking your car self-centres is that it's really
missing the point. The rule isn't there to annoy us - there are strong and compelling reasons why your steering should exhibit self-centring,
continued life probably being one of them
If my car didn't self-centre I'd consider it improperly designed/built and fix it. And fix it properly.
Liam
Originally posted by Liam
My view, for what it's worth, on all these 'tricks' to fool the SVA man into thinking your car self-centres is that it's really missing the point. The rule isn't there to annoy us - there are strong and compelling reasons why your steering should exhibit self-centring, continued life probably being one of them
Liam
Liam
I suspect that if the friction in the ball joints and tie rods isn't excessive that the KPI in most doner spindles would be adequate to pull the steering back toward center.
You can have all the kpi you can fit in. But, with zero castor, it won't self centre in a million years.
It's CASTOR that causes self centreing, due to dynamic geometry shifts and weight(gravity). KPI gives centrepoint and dictates scrub, which
dictates kickback.
Well, that is unless all the texts and engineers I work alongside are wrong!!
Walk down the pitlane at a Sports Proto meeting. You'll see cars with ZERO kpi, ZERO scrub, but CASTOR to the amount dictated by the driver for
feel. That's how it was yesterday, anyway.
Syd.
[Edited on 29/4/08 by Syd Bridge]
