hi guys,
Just completed second track day on the avon using green stuff pads at the front on standard cortina calipers and discs,
standard sierra drums at the rear.
The brake pedal has "gone long", you now seem to have to push the pedal further than before. Cant find any leaks,
and looks to be plenty of material left on the pads.
Anyone got any ideas? do I need to bleed them again?
Les
Possibly boiled the fluid with your enthusiastic driving, try bleeding to rid the bubbles
hi mate i had a frend how fitted green stuff pads to his focus ST and fount gave him a very soft pedal so much that he ownly used them for a week or
so
if not the pads hows the hand brake have you lost any ajust ment on the rear brakes as this can give you a long pedel cos the shoes have to traval
ferver in the drum may be your back brakes are working to hard ?
thought that might be the answer,
damm i hate bleeding brakes.......
les
handbrake also needs a bit more travel than it used to, i guess Ill have to check
what brake fluid you using try this stuff it compterbull with standed fluid so no need to replace any seels not badly priced iver
http://www.compbrake.co.uk/index.htm
[Edited on 2/7/08 by repper]
thanks guys, ill try to sort them tomorow
and report
If your handbrake pulls further up check the adjustment of the rear brakes. If your rear shoes are too far from the drums the pistons have to push
out further, making a softer pedal. Also makes the handbrake have to pull further. Some cars are very sensitive to brake adjustments.
Cheers.
We're up to AP660 now! You ain't boiling that cack.
(1) Check the calipers for a seized piston in one of the calipers OR a pad stuck so can't slide in the caliper in the caliper -- these faults
used to be a very common fault on Fords in the 1970s .
(2) Check the handbrake cable isn't too tight and stopping the self adjuster working.
(3) If neither of the above check the piston in your master cylinder is coming back far enough to let fluid in to make up for pad wear --- easiest way
to do this is bleed the brakes.
[Edited on 3/7/08 by britishtrident]
Originally posted by repper
hi mate i had a frend how fitted green stuff pads to his focus ST and fount gave him a very soft pedal so much that he ownly used them for a week or so
if not the pads hows the hand brake have you lost any ajust ment on the rear brakes as this can give you a long pedel cos the shoes have to traval ferver in the drum may be your back brakes are working to hard ?
