Been searching ebay etc for a pair of long ramps to get the car up on, found expensive ones and your bog standard ( short ) steel ones and found these
which I think would suit and you can make them as steep and high as you like and wont cost the earth.
Any views or has anyone a better idea ?
[Edited on 30/10/08 by TOO BADD]
Maybe a picture here or maybe not !
OK if you've plenty of room!
That's nice and simple, and can be used for heating when finished with
Simon
Halford's normal (short) steel ones work pretty well for £32 a pair.
Trouble with long ones is they restrict access from the side.
If you find problems geting the car on to ramps the can be quite easily modded.
