Digital clocks - anyone used this?
EasyJimbo - 22/10/09 at 01:12 PM
Anyone got one of these, are they any good? They are from digital speedos I think.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&Item=260486627230&Category=72213&_trkparms=algo%3DLVI%26its%3DI%26otn%3D2
thanks
J
speedyxjs - 22/10/09 at 01:13 PM
Same one iv got. I think its a great bit of kit
Madinventions - 22/10/09 at 01:14 PM
Mine are not exactly the same but I used something similar. They work really well and are dead easy to set up, but they can be a bit difficult to see in bright sunlight sometimes...
Ed.
EasyJimbo - 22/10/09 at 01:16 PM
thanks Guys :-)
J
YQUSTA - 22/10/09 at 01:34 PM
I have that exact one in my car works great apart from the fuel level.
check the specs i think it works on either 100 or 500 ohms.
mine will show either half full when the tank is empty or empty when the tank is half full.
just need to get a blackbrid sender and fit it to sort the reading out not got round to it yet.
edit: it is a koso XR-SR
http://www.kosonorthamerica.com/
[Edited on 22/10/09 by YQUSTA]
Jasongray5 - 22/10/09 at 02:26 PM
Does this unit have all the warning lights required for IVA?
Cheers Jas
cd.thomson - 22/10/09 at 02:37 PM
Cheers Jas
all of them apart from brake warning light
EasyJimbo - 22/10/09 at 03:13 PM
Brake warning light, whats this for then?
J
EasyJimbo - 22/10/09 at 03:14 PM
DO you mean handbrake warning light?
J
adithorp - 22/10/09 at 03:43 PM
Brake fluid level. Often linked to h/brake.
rgrs - 22/10/09 at 04:30 PM
WARNING !!
Without modification they will not pass.
All testers were notified that on these clocks it is possible to enter a mode where the current speed of the vehicle is not displayed. Instant fail.
To pass with these you will need to diasble the bottom button.
And as said above you cant see the warning lights in bright light.
Otherwise easy to install and calibrate.
Roger
Stuart_B - 22/10/09 at 05:36 PM
i have this dash in my car, great little unit
stuart
MikeR - 23/10/09 at 11:46 AM
Originally posted by rgrs
WARNING !!
Roger
What is teh definition of disable?
If i mounted this into a dash and had the bottom button covered by the dash would that count?
