Quick Question:
Grease or no grease on a steering boss splines?
I dont think it matters as the only sliding it will do is coming on and off unless that is, if you have an adjustable one.
Grease, every time.
Anything that mates together with the potential to come apart again, should be greased or lubricated to prevent corrosion and (on occasions) an
airtight seal.
PTFE dry lube
you'll wish you hadn't greased it the first time you get it down your arm/a light coloured sleeve
ETA - assuming you're talking about a removable steering wheel boss?
[Edited on 4/1/11 by indykid]
