Black Plastic Sheet
mistergrumpy - 16/1/11 at 12:31 PM
Does anyone know what the black plastic sheet with a pin prick type pattern on it is called? I saw it on Caterhams yesterday and I know it's ben mentioned on here before. They sellit on Ebay cheap enough but I just wondered if anyone local had any, save all the postage and courier messing around.
Thanks.
prawnabie - 16/1/11 at 12:38 PM
Do you mean pinseal?
wicket - 16/1/11 at 12:41 PM
I think you are probably looking for Pinseal ABS
http://www.plastic-sheets.co.uk/eCommerce/product.aspx?loc=3&prod=173
There in Skelmersdale
[Edited on 16/1/11 by wicket]
mistergrumpy - 16/1/11 at 12:41 PM
Cheers all. I'll have a look.
Slater - 16/1/11 at 01:17 PM
I used 6mm ABS pinseal sheet for my rear shelf, looks good, but I found it expanded and warped in the sun. Maybe with more fixing points
it would not warp, ust something to bear in mind.
interestedparty - 16/1/11 at 02:43 PM
For lining a cockpit 2mm pinseal ABS sheet is good. For a back panel I would use 6mm plywood and cover it with vinyl leathercloth.
mistergrumpy - 16/1/11 at 05:44 PM
I have aluminium covered with carpet for the rear panel. It's just the inside, side panels. I was looking at 2 mm. Ebay seems to be champion.
