hi there
what speedo cables do people use in there type 9 gearbox kitcars ? is a mk2 escort cable the norm ???
many thanks
striker-4age
I used the cable from my mk2 Escort donor. The main problem is routing it from the gearbox. I don't know how much room there is in the tunnel of
the Striker but if it's the same as a locost then it is not much. You can buy an angle drive for about £60, but I drilled a hole in the side
panel of the tunnel and ran the cable across the footwell and up over the steering column.
I went to a marine control cable company, handed them my donor car cable (Sierra) and told them to shorten it. Cost £9. I have a type 9 in a Haynes Roadster and it was a squeeze to get it to snake through the tunnel. But its clipped in place and its been OK. A ninety degree angle adapter would be the best route, but they seem a little pricy.
Screw converter out of the gearbox with a transducer attached wired to an ETB electronic speedo.
Seems to be my night for searching...
another locost linky do
I got Speedy Cables to make one up for me as it was going to a rescued Smiths speedo and the end was different to the Ford one. I also used a 90deg adapter so the cable isd in the tunnel.
I use an electronic pick up via ecu from the diff bolts.
+1 on the Electronic Pickup I had a Cable to Electronic adapter and it would jam up causing sorts of problems
changed to a pick up of the blot heads (+magnet) no problems since
Ford Anglia cable has the right end fitting for a Smiths speedo with the small size thread.
Other early 1960s Ford UK cables should also work eg Mk1 Cortina
Im on a VDO 90 deg adapter, came with car...
One of them screw in adapters and an oem gearbox sensor off a IB5 fwd box.
I use an electronic transducer from speedy cables with a short cable from the mechanical drive on the gearbox. It is a pretty tight fit to get inside
the tunnel without over-bending the cable.
After only a few hundred miles the first cable I had came to pieces internally. Speedy cables replaced free of charge and have not had any problems
since with exact samne mounting arragnement as before.
If I was doing it again I would look to find a tranducer that replaced the drive in the gearbox rather that using the external transducer.
Rich
