I have searched and I see several trhreads talking about links to a description of the best procedures for doing a race seat out of expanding foam. I
can't however see any actual links.
Are there a couple of descriptions or DIY guides to doing this in the best way possible?
Thanks.
[Edited on 27/9/05 by jecuk]
I haven't got the link to any site but I know of a couple of ways of doing them. The first is a two part mix which you put into a bag and sit in
or you can use a couple of cans from b+q. I think both would require some sort of frame to give it some strength.
When we've made them we made the rough shape from a ply construction, then put on a bin bag and sat in it and filled the remaining space with
epanding foam. Then cover it with what ever takes your fancy. Gaffer tape, carpet underlay etc...
theres a guide in PPC magazine as part of their fury build.
something along the lines of using a binbag, filled with expanding foam, and letting it set a little bit so its a little bit firm.
then sit in it, but hang on to something so its not all your weight on the foam (which would squeeze it all out.)
i'll try and scan it in later on. (or maybe someone else can if theyve got it)
when I do my foam seats I plan to use some polyurethane foam sheet (camping matting) in the seat base to help stop the base thinning too much.
Try Tim Hoverds site.
There's a link in the "Links" section.
Pat...
I've spoken to the chap(Brian) that runs this firm and he might be able to supply smallish quantities of neoprene.
http://www.techneopro.co.uk/start.html
Hope this helps,
Ian
Who gave you that idea then?
Supposidly thick neoprene diving suit material is supposed to be good .... just haven't a clue where i can get some cheap.
same place all your good ideas come from!
Any update on scanning the article Dillinger?
Pat...
In a race car, If the seat is done in place, is there any need to secure it or will it just expand to fill the space and lock itself into the car?
