I Have just purchased a set of seats minus runners.
As there are going to be at least 2 drivers of my car I realy need to fit runners.
My question is who makes/sells the lowest profile runners?
Rover do.
Metro...
Pat...
I just cut off the runners that came with my ford donor - they werent exactly thick - 20mm or so?
atb
steve
I think the Metro runners are the lowest profile ones and seem very popular with the taller drivers.
What seats did you get Brian?
[Edited on 22-10-05 by RazMan]
I used Metro runners - fairly easy to reduce by cutting a section out of the release handle and refixing. In my case I used Araldite and a sleeve that went over the cutoff ends
