mk roll bar
graememk - 25/3/06 at 11:18 PM
how have you fitted your roll bar? what type of bolts etc.
its a indy if that helps
donut - 26/3/06 at 07:55 AM
I think i used M10 round headed bolts.
indykid - 26/3/06 at 09:23 AM
3 m10 button heads in each foot on mine. 2 on the inside corners, and one in the middle of the outer edge.
hth
tom
mookaloid - 26/3/06 at 06:13 PM
If you are considering entering any motorsport/sprint/hill climb events then you will be well advised to get a proper roll bar with a diagonal and backstays to RAC standard. - Welded on!
Mark
nick205 - 26/3/06 at 07:59 PM
got mine welded on by MK when i bought the chassis
Marcus - 26/3/06 at 07:59 PM
The bolting of rollbars is a worry, I'd weld every time.
Bit of a bugger if you've got a powder coated chassis though!
Mine's a standard MK, with harness bar and boot stays welded on.
Still class it as purely cosmetic though, there's no substitute for an RAC spec bar.
Marcus
jeeby_man - 26/3/06 at 08:25 PM
i've welded mine on as i feel it looks better than having bolt heads showing
