I know that the speedo is checked in the SVA, but are there any rules on how information for the reading is gathered?
This:
http://www.instructables.com/id/NonTraditional-Speedometer-for-Used--Homebuilt-Ca/
could be an option. But it would be impossible to check on SVA.
soooo you like saying fit a radar gun to your car and use it as a speedo? but that will pick up any oncoming traffic and you'll then you'll
be doing 140mph!
if you point it at the ground what’s the beam reflecting off? cats eye's?!
for about £12 you can buy a push bike digital speedo that stores total miles and uses a magnet and reed switch on the front wheel as I have on my push
bike
[Edited on 1/10/08 by Mr Whippy]
soooo you like saying fit a radar gun to your car and use it as a speedo? but that will pick up any oncoming traffic and you'll then you'll be doing 140mph!
for about £12 you can buy a push bike digital speedo that stores total miles and uses a magnet and reed switch on the front wheel as I have on my push bike
^^^ What Mr. Whippy said about a bike speedo as you can calibrate it pretty accurately - must be no more than 10% over/under the correct speed.
Also I think it needs to be visible at night - probably there's a bike speedo with illumination as night-time off-roading is becoming popular
amongst mountain-bikers (but only those with a death-wish!) or I'm sure you could rig up an LED or similar without too much trouble.
Cheers, Pewe.
I guess the other consideration is the Mr SVA needs to be able to test it against a calibrated standard, which I presume they do on a rolling road, so you're limited to measuring wheel speed rather than road speed.
No you point the beam down so there would be no interference from traffic etc.
I thought you were a physics bod? no it would just be reflecting off of the ground, you know, in the same way light does so that we can see the ground!
really using a radar gun as a speedo is quite a crazy idea and would never pass an SVA test, full points though to the sales guy for even comming up
with such a sales pitch
Originally posted by 02GF74
You are gonna have to explain how this works.
Radar sends a beam of something and measures time for reflection to come back. Doing this repeatedly on a moving object will result in the time for reflection changing. The difference in time can then be used to determine the relative speed.
So unless the car is changing the distance between itself and the ground, like taking off in an air-plane-like fashion, I fail to see how it is gonna work realiably, if at all.
The radar needs to point at some stationary or very slow moving object in the distance horizontally e.g. tree, large house, stationary traffic, giant tortoise, pedestrian, guide dog etc.
Just to clarify ..this will be a Doppler Shift radar rather than a conventional radar. It doesn't take repeated readings to measure speed.
I don't have time to explain so you'll need to look it up in Wikipedia or similar to see what I mean.
[Edited on 1/10/08 by jeffw]
I don't know, the bike speedo thing sounds a lot easier and probably a lot cheaper in the long run. Small too, and easy to set up.
I think I should go that route myself, even though I have bought a fancy set of gauges with my own custom faceplates etc. I have no idea where the
thing plugs into the car! A few things to sort before I get down to it in earnest.
