Chassis Plans
eddie99 - 17/6/09 at 06:03 PM
Hi Guys,
Got a friend wondering about building his own wide chassis, Anyone downloaded/used the GTS chassis plans?
Good quality?
Ed
omega0684 - 17/6/09 at 06:07 PM
i have the McSorley book chassis plans in pdf its thats any help?
twybrow - 17/6/09 at 06:10 PM
A friend of mine did it. He has built the chassis, but said there were several parts that just didn't have the required detail on the drawings.....
handyandy - 17/6/09 at 06:49 PM
How about the Haynes Roadster ? not as wide as some but wider than the Ron C chassis.
andy
eddie99 - 17/6/09 at 06:55 PM
He said something about you cant put smaller than 15" wheels on a haynes roadster and he wants 13" i believe
handyandy - 17/6/09 at 07:05 PM
yes that is the case if you use alloy wheels but i believe some steel wheels will fit, don,t quote me on that tho as i,m using alloys, is there a certain reason for wanting 13" rims?
maybe still an option if the wheel size isn,t an issue, as all the plans are in the book & easy to follow.
hth
andy
James - 17/6/09 at 11:27 PM
Or build a book chassis and add 4" to every lateral chassis rail.
HTH,
James
