PU bushing inner/outer tube length???
I-man - 8/2/08 at 10:33 AM
I bought a PU bushing kit from Darren.
The internal steel tubes are cut with different lengths, +/-3mm. Could somone tell me what the lenght should be. so I can cut new ones.
Also what lenght should the wishbone PU Tube be? these I will make myself..
(I have GTS "U" brackets for the wishbones but they where bent with an opening +/-5mm)
Thanks,
I-man
DaveFJ - 8/2/08 at 01:07 PM
Ere we go again....
<ducks for cover>
(Search is your friend!)
blueshift - 8/2/08 at 08:14 PM
I-Man,
I have a drawing with dimensions of Darren's polybushes and tubes, assuming they haven't changed. It's called polybush.pdf, not sure if it's still on his site? I think my set of bushes came with a printout of it too, but that was some years ago.
if you want a copy, u2u me your email address.
I-man - 8/2/08 at 09:29 PM
Thanks mates, I found the Answers
I-man
