For Sale
Complete R1 Set Up
1999 R1 Engine
Fitted with Barnett spring clutch and strong springs
EBC Kevlar Clutch Plates (Brand New)
Reversed standard air box (fits under an Indy Bonnet)
Fitted with Mk prop Adapter
Oil Cooler bolt drilled and taped oil pressure sender fitted on S/S pipe.
Vicky Green full car wiring loom with integrated R1 Loom and all control boxes.
Modified prop shaft to fit
Home made Aluminum and S/S gear change mechanism (Its Good honestly, Rose joints and adjustments )
Speedo Healer
Dash Board with Electronic Gear indicator ,Bike Dials ,Clock and Hand brake warning light.
Mk Exhaust Manifold and Carbon Can.
Battery and Battery Clamp(S/S)
Photos in my Photo Archive
£1400
I wish this was for sale 6 months ago! Looks like a good deal for someone so back up it goes.
Thanks for that.
It seems you are the only one who thinks so!
