FS FULL JAW System
Lars - 11/4/10 at 09:19 AM
I have for sale my full JAW system.
Comes with sensor, and fitted in a little black box.
THe box even has a little fan fitted to keep it cool.
It also come with the optional display.
Just requires the sensor to be screwed in and 3 wires connecting (+,earth, 5v (to ECU, if applicable))
PLease note that I have trimmed the corners of the PCB slightly to make it fit into the box.
Also i used spade connectors to connect the wires to the sensor plug, and then filled this with a hot glue gun.
Image deleted by owner
Looking for offers in region of £80 +P&P
[Edited on 11/4/10 by Lars]
See below, now £70 posted to mainland UK
Danozeman - 11/4/10 at 04:57 PM
what actual make is it or is it a home brew?
RobLyon - 11/4/10 at 05:01 PM
Its JAW which stands for just another wideband. What megasquirt is to ecus, jaw is to widebands
Danozeman - 11/4/10 at 05:32 PM
ah i see. Must be a kit though?
Lars - 11/4/10 at 05:41 PM
Yup, Rob you are correct.
It is a wideband controller.
The manufacturer has a website, www.14point7.com
where you can get all the software etc.
I soldered this up myself. WHile I am not a professional, I did solder my whole megasquirt up as well (a lot more complicated), and have not had a single problem with either.
hmmm ... Just looked at the website and it seems that the prices were dropped before it was discontinued.
So I'll drop it to £70 posted (in mainland UK)
Lars - 13/4/10 at 04:49 PM
ttt
will be ebayed this weekend if no interest
