Sierra steering rack cut down currently 4" wider than an MK rack can still be cut down further if required or use on + 4" chasis £20
Cortina Hubs / uprights £50
Cortina font callipers useable have had new seals in last 3 years but ideally require reconditioning £20
Cortina Brakes (Westfield) reconditioned using big red replacement pistons (stainless) cost £100 last year £50
Lower wishbones (locost) made by MK oval tube £45 with bushes
MK Upper wishbones (book locost design) £20 with bushes
GEMS ecu with loom 1.8 zetec map £70.00 does not require edis only TPS, Crank sensor and coil pack
Twin 40 dcoes 31 on zetec manifold with ford TPS and linkage(older 40's not 5 progression holes 4) £220
facet red top fuel pump £25
Fuel regulator £10
Sierra dash £10.00
locost nosecone £20
rear arches orange £35.00
Front arches black with wingstays for cortina strong design £30
Any interest u2u me
[Edited on 19/10/10 by austin man]
Will you post the rear arches??
could do but would have to use TNT etc to limit damage not sure what the postage and packaging would be
Where are you located
u2u
U2U Re ECU
replied
any chance of a pic of the cortina wingstays please?
cheers
pics of wingstays in my archive
2nd dibs on the wing stays if they haven't gone yet
JB
Blimey - your Cortina uprights are cheap. I have a spare set otherwise I'd have had them... get in there people.
i'll take the arches if they are still available.
arches are provisionally sold sorry
I am trying to keep prices low for locosters if I put them on the bay the would be higher.
ok, if they dont sell, let me know, thanks
tony
im looking for an ecu...what model is it
