I have for sale a rear axle it is about 52 inch wide and very strong but not that much heavier than an escort axle probably similar to an atlas axle
in weight but i would guess stronger, this axle is .... Wait for it... off a Daihatsu fourtrak,
Now before you run away it is no landrover weight axle and it is made by Toyota as we all know and it as a decent ratio of 3.7 to 1, as a
propshaft thrown in to make your own up and is complete with wheel nuts etc and there is alloy wheels or steels in 15 inch that will fit the five stud
PCD.available at scrap money if required And all this the complete axle and prop for 25 of the queens pounds. Be bold be different it is a good
axle. if interested it is in yorkshire close to the north lincs border.
