hi im stripping my lotus seven project as i have just bought a global gt and need to thin out my projects as iam ruunning out of room so its goot to
go i had about 3/4 of the parts and will start listing them on hear and eventually ebay if no locosters can make use of them i will put more pictures
on here and more items as i clear out my sheads if you are intrested in any of it then please call me on 01359233157 or u2u me
I have a set of gas shocks and springs like new with a few marks never fitted to the car but never been down the road don’t have the boxes anymore but
they are as good as you will get will upload pics tomorrow and check the spring ratings I paid £247 from rally designs they the ones with the
adjustable dampening I am after £150 or very near offer that is £100 of retail price
I have a 4.1 diff still in the axle with drums the diff is in good working order the axle has been painted with hamerite with a good thick coat the
diff was stripped cleaned and inspected by escortec when I got it the drums have been sandblasted and painted im after £100 for it
I have a wheel and removable boss for sale never fitted to my car bought it to go on my lotus seven that I was building but I bought a global gt last
weekend i am after £50 it’s like new global already has one is 255mm diameter
I have a set of 15 inch 7j rims they are the same as the team dynamics multispoke’s in black alloys they are brand new in the box never been of the
box still wrapped except for one to take pictures they are 4 stud with 108 fitment to fit ford Citroen pergueot and some others I will include some
wheel spaces as well im after £200i have a set of stainleess wheelnuts for an extra £10
I have a brand new never used just unboxed obp pedal box with twin break cylinders and bias bar it bhas a 25x25mm recess in it to fit straight up to
the bulkhead .it has two master cylinders, 2 resevoirs and a pair of braid lines to the resevoirs its for a cable clutch but could easily be adapted
to hydraulic clutch the pedals arein a 5.1 ratio it cost me £269 im after £140 or near offer it’s a £129 off retail price
I have a caterham dry sump bellhousing to convert a rover k series to fit a ford type 9 it has a few marks and a small crack that has been repaird but
will not affect performance it can be used with an apolo tank that you can buy from caterham to save space im not certain but can be used with a dry
sump these are £576 new but I will take £130 or near offer
I have a group a hydraulic hand break with wildwood master cylinder still all bagged up bought it for the seven but never fitted it rally designs want
£80 I would take £40 would keep it if the global needed a handbreak
I have a rover k series 4 branch manifold with individual headers with a 4 to 1 collector and a Westfield silencer the headers have just been wrapped
with dei heat wrap this week which is not cheap nasty rubbish there’s a whole reel on their which is about £50 worth the silencer has a couple of
small bumps in it but nothing major and will not affect performance it is not pristine but is in vgc this setup will give a reasonable increase in
performance over the standard this setup would cost around £950 new want £250
I have a set set of front wish bones uprights and calliper’s the brake calliper’s have just been refurbished and anodised in gold by a local firm
along with the wishbones and uprights the hubs have had a new bearings and alloy grease caps there from a Haynes locost and possibly some others I
have been told the breaks and uprights were from a Cortina but I am uncertain I have a brand new set of pads for the buyer to fit there are a few
marks but you probally wont notice when the wheels are fitted and will throw in a steering rack as well I am after £120
I have a radiator that I have been told is from a mk2 escort but I’m uncertain it still has the suppliers name tag on it never fitted £45 ono
[Edited on 2/10/12 by metro6r4]
might know someone who could want pedal box. will let him know
I will take the pedal box please.
James
Hi
I will take the handbrake and cylinder also.
James
Bloody 'ell - I only went to the toilet and the pedal box sold !
Interested if it falls through.
U2U sent
i am in bury st edmunds the pedal box and hand break have been provisionaly sold to hicost with first dibbs on the handbreak going to unijacko67 if
the sale to hicost falls through
i will be adding a straight cut type 9 gear box that has only just been built and not used
a rover k series race engine with exige throttle bodies profeesionaly ported custom head uprated mls gasket new caterham ultralight flywheel new ap
clutch new caterham starter emerald ecu remote mount oil filter kit with oil cooler, and lightweight cranck pulleythe engine was from an elise having
only done 44 thousand it has been profesionally mapped and is producing 220hp
U2U sent regards dampers
Adrian
U2U sent
where were you when i needed new wishbones and shocks a week ago!
just oreder some new bones to be custom made.....
arrrrgggghhhh
here is a picture of the steering wheel and boss
i also have a chasis for sale including some pannels bonnet and scuttle panhard rod and trailiing arms im after £100
How much is the steering wheel please ?
with a quick release boss £50 plus postage the boss cost me more than that may still have the horn button as well somewere thats not including postage but that wont be much
Anymore info on the Type 9 gearbox? Is it still available?
wishbones calipers hubs and uprights are gone as well as the shocks the gearbox is for sale will get pics and post more info soon
i have a bosh 044 fuel pump brand new in the box with fitting kit Probably, the most popular aftermarket fuel pump. Capable of providing 300 LPH free
flow and 200 LPH at 5 bar (or 72.5 psi) for up to 685 BHP.
cost me £150 will take £100 ono
Hi me again I will take it, thanks.
What about the post
Regards
James
hi hi cost i have sent you a u2u
Just paid via PayPal
James
fuel pump and wheel have now sold
i will be putting up a fuel lab adjustable fuel presure regulator and a fuel lab 100 micron serviceable fuel filter tomorow
silky 16v you have u2u
i have a straight cut type 9 gearbox that has just been rebuilt by first motion and hasn't been used since i still have the receipt. it cost me £1650 without the cost of purchase it is fitted with a caerham k series bellhousing at the cost of £300 just had a caterham clutch release bearing. everything on this box has been uprated or renewd it has been fited with a tranx gear kit uprated oversized rollers and bearings it comes with a large collection of coomma gear oil this set up is good for 300hp i will take no less than £1200
all orders dispatched
dry sump bellhousing now sold will be adding more soon
i have a dragon performance rev counter with shift light it has a telltale feature,the shift light is programable and the gauge can be set for 4,6 or
8 cylinder cars comes without box or instructions used 3 times take £15
[Edited on 7/10/12 by metro6r4]
U2U on its way for the rev counter
Bellhousing arrived safe and sound, and its the top banana! - thanks mate!
Hi there I have a Haynes locost chasis for sale it comes with a pair of ford zetec engine mounts most of the ali body panels, nose cone, panhard rod,
scuttle bonnet ,cycle wing stays and rear trailing arms.it also has two steering racks one is a 2.9 im not sure what the other is The trailing arms
have had pollybushes fitted as well as the panhard rod.i may also have have some cycle wings
somewere and a set of pinto engine mounts and ali rack clamps if I can find them I will include them in the sale cash on collection is preferd and
please remember there is a lot of stuff here so you will need a van or trailer to collect it all £120ono
[Edited on 13/10/12 by metro6r4]
will take £160 for the wheels with the spacers and stainless wheelnuts
double post
If offset is right for me consider them sold. Cheers u2u sent.
Cheers, consider the wheels sold. Happy to arrange courier.
thats 2 sets of those wheels you have now jacko
Yeah, two sets of wheels, but no car. It should come together quite quick once I get started.
