Hey up all,
Putting this on here for a friend of mine...
Brian James Clubman trailer product code 100-0140 (http://www.brianjames.co.uk/pdf/BJT_UK_2011q3Clubman_1.pdf).
Single axle.
Gross capacity 1300kg
Load capacity 980kg.
Brakes and all electrics fully functional. All lights working including marker lamps on the corners.
Bought brand new October 2011 after 3 month's on the waiting list.
Covered around 500 miles.
Ramps included - these are secured beneath the loaded car when not in use.
Registration plate holder retracts downwards for easy loading. I knocked the registration plate lamps off but have replaced both with new, larger
Britax lamps.
Hitch lock included.
Bed dimensions 13ft x 6ft3.
Total dimensions: 17ft9 x 7ft8.
Bad points:
Jockey wheel has taken a few knocks but is still fully functional
The underside of one ramp has a black patch - presumably spilt some battery acid on it at some point.
Few scratches and areas of discolouration
£1200. Pickup from Gloucester preferred but can deliver at £1/mile (one-way) to max 100 miles.
Any questions, drop me a msg and I can put you in contact with him. Will try and upload or link to photos tomorrow.
mads
photos are on facebook: https://www.facebook.com/media/set/?set=a.10151100164627035.432006.503922034&type=3
will get photos off him for those who aren't on facebook.
OK, photos now available on Gumtree
