hi im having a major clear out heres a list of what i have prices do not include postage little things will be £9 at the most big things i would
perfer pick up from rh6 9gj but i can put this on a pallet for about £60
2.0 mondeo engine i bought a complete car and had it running before it was removed but has been sat around 6 months under cover come with home made
engine mounts as i had started to fit it in a dutton kit car it still has the standard sump but has been cut away to get the starter motor to fit it
does not have a clutch on it i have it if i find it you can have it also
£120
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4262.jpg
ford type 9 gearbox come with gearlever not in picture i bought this of ebay said to be good but i have not tested it £100
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4260.jpg
spencer ashley throttle inlet set up comes with all the parts you need cost over £200 im after £160
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4261.jpg
megasquirt ecu 2.2v with leads and cd £100 now sold
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4241.jpg
premier wiring loom for serria type kit car brand new unused with all paperwork £120
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4243.jpg
nose cone 26" wide at the top looks unused has hinges on the front and a few minor marks £35
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4248.jpg
fuel swirl pot £40
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4251.jpg
complete mondeo zetec loom and ecu code bash £25 now sold
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4242.jpg
mondeo rear brake calipers and discs £25
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4245.jpg
5 westfield wheels 2 good tyres 2 not so good one new they are in good conditon they are 185/60/14 i dont no the offset they have c46 on the back
£100
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4249.jpg
dutton screen 34.5" at the black seal on the screen £25
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4250.jpg
ford vr sensor with tails £10
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4252.jpg
ford coil and plus not sure i think its sivertop one £10
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4253.jpg
2x ali tube 30mm wide and 40cm long great for hoses on zetec conversion £2.50 each
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4254.jpg
injection fuel pump dont know what from £30
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4246.jpg
carb bike type fuel pump £20
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4255.jpg
fuel filter new £7.50
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4247.jpg
cut off switch used £10
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4256.jpg
small mitsubishe aluternator untested no pulley £10
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4257.jpg
zetec mondeo aluternator £10
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4259.jpg
ford master cyclender has 3 ports dont no what it off untesed £7.50
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4258.jpg
i have some windows i bought for about £350 for a van camper converstion 2 open and two closed all brand new they are 40" wide and 15" tall
all with seals to fit and panel van
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4264.jpg
towing dolly i have had this about 2 years only used it twice but it works great could do with a little paint and tlc come with ramps and a small
winch tows really nice £200
http://i31.photobucket.com/albums/c363/street-fighterblade/DSCF4265.jpg
thats it for now i also have a dutton kit car chassis and body work comes with v5 and vin plate im after £350 i will sort out some picture any one is
intersed
all item will go on ebay at the weekend if no takers cheers ian
[Edited on 18/2/13 by doddy]
[Edited on 19/2/13 by doddy]
First dibs on the ECU and Loom please. Can PayPal if ok?
U2U re: Megasquirt.
squirt if still available can i have it please
U2u
u2u replayed
Bump
zetec engine and ali tubes now sold
[Edited on 20/2/13 by doddy]
primier loom now sold
Last bump before it all goes on ebay
i have started putting it on ebay here a link
1978 DUTTON BLUE kit car with v5 project rolling chassis | eBay
What camper were the windows for? Pictures not right?
hi they are for a iveco daily but i think they are universal
here are the seals
its all brand new
[Edited on 27/2/13 by doddy]
Thanks ,I was hoping they were vw T4
they may fit as long as they fit inside the panel
I want the T4 windows Cheers though
Great guy to deal with
Roohunter
