Aluminium wheel spacers
beardmore4072 - 22/3/13 at 03:09 PM
Hi a pair of 45mm aluminium wheel spacers with studs and wheel nuts. £60.
Pics are in photo archive in for sale folder. Thanks
unijacko67 - 22/3/13 at 09:32 PM
Jesus, I’ve just had some 40mm ones made, whats the pcd and inner centre bore (half sheft) and outer bore (wheel). I will see if I can justify a spare set if 108 pcd and bore sizes are ok.
beardmore4072 - 23/3/13 at 02:52 PM
Sorry forgot to put it in the description. The pcd is 4x108 and both the inner and outer bore are 63mm. Thanks
james jones - 24/3/13 at 10:10 AM
u2u sent
number-1 - 24/3/13 at 04:02 PM
Sorry to hijack the thread....How much did you pay for these to be made? Ive got 4 x 130 hubs and was looking at getting some made so i can use a more common pcd
welderman - 25/3/13 at 11:46 PM
Are there's still for sale ?
beardmore4072 - 26/3/13 at 10:17 AM
Hi sorry these are sold. Also not sure how much they cost to make i bought them off someone a while back. Thanks
unijacko67 - 26/3/13 at 10:21 PM
If it helps I paid £42 inc delivery for 2 x 150mm diameter by 50mm wide bits of aluminium (Aluminium Warehouse) then about £26 for 8 x 65mm studs/nuts and delivery. Then £40 for machining. Cheers.
rodgling - 26/3/13 at 11:02 PM
Should be pretty easy to make if you have access to a lathe? Might be tricky to get the holes in the right places but doable.
