I've just upgraded again and have these parts for sale now. I'm looking for £120 for motherboard, ram, cpu and cooler and £50 for the
screen. For some reason I can't get the other pictures working, I'll try again later.
AMD phenom 2 x4 955 Black edition processor
This is a quad core processor running at 3.2 ghz. It's the black edition version which means it is unlocked and can be overclocked. I had it
overclocked at 3.8 ghz for a few months with no problems at all. They can be pushed further but I didn't want to be greedy.
Gigabyte Ga- M68mt motherboard
8gb ddr3 ram
Acrtic cooling freezer pro 64 cpu cooler
Acer 23 inch widescreen pc screen
Size 23"
Maximum Resolution 1920 x 1080
Pixel Pitch 0.265 mm
Refresh Rate 60 Hz
Type Active Matrix Color TFT
Display Area 509.76 x 286.74 mm
Response time 5ms
Contrast Ratio 40,000:1 Max (ACM)
Brightness 300 cd/m2
Viewing Angle 160° (H), 160° (V)
Colors 16.7 million
[Edited on 16/6/13 by Davegtst]
What size case does the mtboard fit Dave?
It's a micro atx size (24 x 20 cm) but I had it in a full size case. I think my psu is a 680 watt that I got from maplin for about £45 but it depends what graphics card you are going to use. Either way they aren't that expensive. I may have a nvidia gtx 560ti for sale soon too if thats of interest.
Tempted by the screen, but you are too far East
Where abouts are you rupuredduck?
All still for sale minus the ram. £100 for the motherboard, cooler and cpu. £50 for the screen.
MK is about 45 mins form me if you wanted to make a detour.
Motherboard and cpu are now gone. Screen still available.
