need some more space in the garage and have sold 1 set of these already.
13" black allyecats from my radical 6" x 13" fronts with 160-535 dunlop formula ford slicks
8" x 13" rears with 170-570 dunlop formula ford slicks
also have a full spare set of 4 slicks in these sizes to go with them
all wheels and tyres are obviously used but wheels are all straight and in decent condition for a race car and tyres have plenty of grip once warm!
all ford pcd and rear offset is suited for car with wide track rear and wide arches. they will stick out past a standard rear arch on standard offset
7's
£235 for the lot! as i need the room.cheers
bumpy bump! will listen to offers
Dan, what are the offsets, I want another set for the Fury for next years track days with slicks so am interested but not sure if they will fit?
6" fronts around et13 8" rears around -5 cheers
Cheers, Dan I'll check soon and get back too you.
i think my old fury ran et18 front et 6 rear so the back face of the wheel will be 3mm wider at the front and 11mm rear so possibly not too bad at all!
i think my old fury ran et18 front et 6 rear so the back face of the wheel will be 5mm wider at the front and 11mm rear so possibly not too bad at all!
Yea I think I have plenty of space at the rear anyway and if I get the brakes sorted I need slicks cheaper than 888's!
i had rear arch spats on mine to keep the wheels inside the bodyline! looked nice
Dan, the rear wheels are going to stick out too much for the arches with out adding some spats and i'm not keen on doing that yet as I have enough to be doing and I don't want it looking like an out and out track car, so I'll have to pass on them which is a real shame
