Having a garage clearout, and have various parts left over after my engine and gearbox swap (and a few other bits too), collection only on the heavy
items, happy to post smaller items if requested if you cover the cost.
Pics of everything HERE
1.8 Zetec flywheel £20 - GONE TO MikeR
BRAND NEW Gates multi-V alternator belt (5 ridges / 4 grooves) 1063mm - £5
Mondeo gear linkage UJ, NEW but had extra hole drilled before change of plans - £3
The below items are FREE (will be scrapped if no takers):
Zetec E cam sensor
Zetec E cam pulleys
Used clutch cover & clutch plate, both look in good condition but have done 40k miles in the Mojo - GONE TO MikeR
Focus gear lever & single 1.8m push pull cable, slight damage to one end but useable, may be useful for a middy build
Ring rear fog light, used for SVA only a few years ago, then swapped for LED unit
FIAMM single horn unit, used for a few years and then swapped for something louder, this should get you through IVA fine - GONE to WOMBAT
[Edited on 24/11/13 by nre]
Flywheel and clutch please.
I can collect during the day if thats ok? Evening will take a few days to organise due to children.
Can I have the horn please"...................sounds so wrong but I need one"...........oh dear.
Seriously, I will u2u.
u2u isn't working for me. Still want the flywheel but been ill the last week. Will try and u2u tomorrow from a different machine.
REMOVED FOR SPAM
[Edited on 4-12-13 by Fozzie]
