Here are some of the items I want to be rid of. I am amazed at how much stuff I have accumulated so I am having a good clear-out.
Please fell free to make offers
They are near Folkestone in Kent [CT187AX] but I am happy to post at your cost.
I can send pictures if you let me have an email address (I will slowly be trying to upload to my archive)
Two rear cross members for a Type 9 gearbox - both are in good used condition and come with the rubber mount and the mounting bolt + bell shaped
washer.
Brake master cylinder and reservoir from a Mk V 1.8 TD Escort - I have taken it apart so that it can be inspected - used but good condition
Power steering reservoir (metal) + cap from Toyota (Supra?) - used
A pair of Sierra Track rod Ends (new)
A pair of Sierra track rod ends (used but good)
V6 Ford Cologne (& Pinto?) mechanical fuel pump & gasket - used
Sierra rear wheel bearings - 2 sets (new)
Starter motor - 1.8TD Mk V Escort - used but good
Starter motor - Lucas 5M90 - recon unit - fits ford V6 ( & Pinto?)
Starter motor - Lucas 2M100 - used but good - Ford V6
Front (Gearbox) end from Ford propshaft - I believe fits Type 9 4-speed (shaft is 30mm OD and 18 splines)
Front (Gearbox) end from Ford propshaft - I believe fits Type 9 5-speed (shaft is35mm OD and 25 splines)
Sierra sunroof trim surround and handle & handle surround panel
Ford servo (poss transit?) - new - m/c mounting bolts are approx 64 mm apart
Sierra Mk I plastic header tanks - one has screw cap and one has metal rad cap fitment (no cap with this one) - both used but good and clean
Fiesta Mk II header tank
Escort V header tank (screw cap)
Sierra plastic fuel filler pipe complete with ford cap & key
Ford V6Ford V6 (Cologne)
clutch pressure plate - n/o/s
engine front timing cover
Flex plate (for auto engine)
V6 Bosch electronic distributor
Radiators
Granada Mk II 2.8 radiator - effectively new - was trial fitted but never run on the road
Escort V radiator - used - quite a few bent fins but watertight
Sierra 4x4 radiator - used
Ford horn
V-belt pulley on adjuster arm (80mm diameter)
RV8 ally elbows for air intake system
RV8 air box (SD1 etc)
Steel engine mount arms (pair) - Pinto
Sierra wiper motor x 2 - used but gwo
Sierra wiper motor and cut-down linkage (adapted for Robin Hood but should fit other LSIS cars) - gwo
Pair of wiper arms - adjustable length >12"
Rubber handbrake gaiter x 2 - one for Cortina IV/V & one for Granada II
Rear view mirror (Sierra)
rubber gear stick gaiter
Ford washer pump motor and rubber pipe - used
Fuel Vapour Separator pot x 2 - Sierra - one has fuel hose attached and one has been painted - both used
Radiator temp thermostatic switch - threaded to fit Ford (and most other) radiators - On at 103 and off at 93 degrees - new
Ford Universal Joint Repair kit (90 AG 4635AA) - n/o/s
Type 9 gear stick - knob is marked for 4-speed but it will fit a 5-speed 'box as well
V6 Oil Filter x 2 - Delco filters bought for V6 cologne but I believe they will fit Pinto engines as well - new
Sierra plastic steering column bush kits - 3 new & one used but good
Type 9 Reverse switch inc wiring & plug
Ford Cortina V6 2.3 ignition amp & module
Used pair of underslung exhausts for a Pilgrim Sumo (Cobra replica) inc down-pipes for V6 Cologne engine - 48mm OD mild steel pipes with two narrow
silencers on each side. [passed SVA noise test with these]
Used pair of underslung exhausts for Dax 427 Cobra replica - 2" OD mild steel pipes with one silencer on each side
4 silencer boxes - n/o/s - originated from Ford - still have labels on some
Sierra rear driveshaft repair kits - some metal cups have 73mm OD [83BX4K258AB] and some are 77mm approx [83BX258BB] - n/o/s/in ford boxes
Sierra oil seals x2 (approx 65mmOD [85AB1190AA] - n/o/s
Sierra oil seals x2 (approx 72mm OD [85GB1175AA] - n/o/s
Sierra caliper seal [81AB2B107AA] - n/o/s
Sierra accelerator pedal - used
Quote - Front (Gearbox) end from Ford propshaft - I believe fits Type 9 5-speed (shaft is35mm OD and 25 splines)
Am very interested in this item, 1st dibs pls. Will check my T9 box to verify output shaft dims.
Here are a couple of pics (can't seem to upload to my archive)
[img]
[/img]
[img]
[/img]
hi,
how much for a type nine gear box rubber and dished washer?
Originally posted by teegray19
hi,
U2u sent ref gear stick
Is the "Starter motor - Lucas 5M90 - recon unit - fits ford V6 ( & Pinto?) " still available, and if so how much are you looking for?
Hi Dave
Yes the starter is still available
[img]
[/img]
[img]
[/img]
[img]
[/img]
I bought a recon unit as a spare for my Cologne engine in my Robin Hood. Car has now gone so it's surplus to requirements.
How about £15 + postage?
Let me know if you have any questions
Robin
Can I get a price for the type 9 reverse switch and wiring and also the mechanical pinto fuel pump?
Hi, interested in the new Sierra Track Rod Ends .
How much and how much for postage ?
[/img]
[/img]
[/img]
[/img] quote:
How much and how much for postage ? Cheers
[/img] "Type 9 gear stick - knob is marked for 4-speed but it will fit a 5-speed 'box as well "
Is this still available, can you confirm it is a type 9 but with an odd knob on top, if so how much delivered ?
I'll take this if it's still available......
IanM
IanM
