Mk indy chassis, has been used good and straight. Powder coated black although could do with painting. Alloy floor, side panels, rear panel and
transmission tunnel all included.
Fitted with floor mounted pedals and master cylinder including all copper brake pipes.
Full set of wishbones and rear uprights,
Roll bar,
Set of avo shocks,
Also have a fuel tank and straps.
All need clean/ refurb although 100% serviceable.
Offers invited!
C'mon...give us a ball park to play in! It's exactly what I need but at the moment I've saving my pennies for an impending court case....... Having said that..: I've been looking at second-hand/unfinished chassis and I'm amazed by the difference in price. A brand new chassis (with dubious welding!) for £500 or a new pro-build one for £200 (wife found out how much hubby was spending!!)...... Crashed and bent second hand ones for between £50 and £800!!
What parts do you want???
If you can buy a pro built chassis for £200, I'd buy it!!!!!
My current car has been built from any old random bits of washing machine/fence posts/string/earwax/plywood/bean tins, etc. I've built by own De-dion and sorted the rear end but I still need to widen the front track and make it less crap. That still leaves me with a good rear and front but the most wibbly chassis that has even tried to steer straight. So my plan was to drop my body over a Locost chassis. Ideally, a rolling chassis but I have a quick-rack (with PAS) and the LSD De-dion.
I think the whole package is worth £1000
I almost bought the pro-built one but then I'd need the wishbones, uprights, etc and it would need hacking to bits to get my De-dion to work. I'm looking for a cheap way out!
[Edited on 9/7/15 by nero1701]
[Edited on 9/7/15 by dilley]
Why won't it come with the log-book? Are you using it on a ringer ?
[Edited on 10/7/15 by nero1701]
What is your problem? You have no idea what I have and what I do.....if you're not interested keep your nose out and concentrate on your own life. And for the record, I have 3 chassis.
Btt £1000 all in Ono
Btt
