Full Sierra front brake kit. Comprising of calipers (recently painted in black vht paint and laquer) fitted with mintex 1144 fast road/track pads,
vented discs and braided lines (not pictured) to suit. £75 collection would be ideal as postage will be quite expensive however happy to post at
buyers expense.
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
Wilwood Powerlite smartpad P/N 150-8813. £18.50 posted
[img]
[/img]
Sierra rear mintex pads MDB1287. Covered approx 500 miles. £8 posted
[img]
[/img]
Stainless steel silencer (repackable). Overall length 32.75”. Silencer length 21.5”. Diameter 5.5”. Attachment pipe 2.5”. £60 posted SOLD
[img]
[/img]
FAE 37410 radiator temp sensor 102/93 switching points. M22x1.5. £4 posted
[img]
[/img]
Rear number plate light. £3 posted
[img]
[/img]
Battery clamp. £3 posted SOLD
[img]
[/img]
Herringbone edge trim (ideal for IVA) 1x1.2m length and 2x1.77m lengths plus various short offcuts. 14mm tall, will grip 0.5mm – 3mm thick material.
£7.50 posted SOLD
[img]
[/img]
Pipercross PX500 baseplate to suit Hayabusa throttle bodies. £25 posted SOLD
[img]
[/img]
Remote clutch reservoir with 10mm push – on fitting £7 posted
[img]
[/img]
Wipac 95mm red light E11 marked with mounting housing. £7 posted
[img]
[/img]
[img]
[/img]
Pair of 7” chrome headlights. A small amount of rust spots on the underside. £35 posted SOLD
[img]
[/img]
[img]
[/img]
[img]
[/img]
Oil pipe made by ThinkAutomotive, never used. -8JIC 90deg female one end and ½”BSP 90deg female the other end. Swaged fittings. Approx 58 cm long.
£18.50 posted
[img]
[/img]
Stainless steel overbraid 1x2m length and 1x4m length. Will fit hose upto 21mm external diameter. £30 posted
[img]
[/img]
Wilwood master cylinder 0.625 with integral reservoir. £18 posted SOLD
[img]
[/img]
Accusump electric valve £50 posted
[img]
[/img]
[img]
[/img]
Clutch master cylinder bracket complete with linkage. Ideal if you want to use a motorbike rear brake master cylinder. Not sure if the master cylinder
fitted is any good. It worked fine when it was removed a couple of years ago. £10 posted
[img]
[/img]
[img]
[/img]
Cosmic universal fitment wheel spacers set of 4 (5mm thick) £12 posted SOLD
[img]
[/img
[Edited on 5/2/16 by b3ngy]
[Edited on 6/2/16 by b3ngy]
Hi,
Could I have the master cylinder, edge trim and battery c!amp please?
Ian
No problem Ian. I'll package it up later and get a combined postage cost. I'll u2u a total later on.
I'll take the headlights off you
Tell me where to send payment
Regards
Steve u2u sent
Payment sent
Hi there, away home to measure up my Striker for silencer. You know what make it is? Looks clean, any dents or scratches?
No idea what make it is. Condition wise there are some scratches on the underside and also a mark on the inboard side where the old mounting bracket was welded on. You can't see any of this once mounted. No dents.
